The audio circuit in the 25/29 radio's is different and/or better then what's in export radio's. I know I am not explaining it correctly but that is why in a shootout most run the old school Cobra/Uniden radio's. We need one of our many techs to chime in here.
Go here...
https://en.wikipedia.org/wiki/Envel...ower required at each instant of transmission.
Then discuss the efforts of Phase Modulation - rectified into a envelope...
Then compare that to the AM Regulation and it's limitations.
Between the two, you can see where the Diode used in a 29 (READ AM ONLY) radio simply clips off negative going information while passing positive going and DC Bias...
The AM Regulator - has limitations on both POWER is can pass, (Pass Transistor) and the Regulation it needs to provide DC carrier bias - Your carrier.
With these limits - the 29 simply wins due to the level of DC Bias present mixed in with Audio into an Envelope...
Cobra 29 uses 12 Volts - applied to Finals, while AM Regulation uses DC Bias of 4~6 volts (1/2 supply rail) and audio power is impressed upon it...
Limitations begin where the Audio and the envelope easily exceed the ability of the lowered DC bias to handle the power of that envelope sufficiently.
Now...I will also bring up, your
130% Modulation - is possible, but again your DRIVER is the audio AMP Chip and the extra capacitance used to push it onto the DC Bias.
Compare it (Phase Modulation) to the AM Regulation - you see where the voltage multiplication possible thru transformation of DC Bias into a signal applies more voltage and power component than possible with AM Regulations' saturation and the voltage supply for 1/2 the rated per needed carrier to envelope - is more negative going - even when DC bias is allowed to pass.
Now if you rework say, the 148 GTL per this thread
Over 130% Modulation there are other efforts you can add into the AM Regulation to help with Envelope - but that can only be discussed once the members understand how dangerous this information can be in the wrong hands...
I was working an Asymmetrical Thread at CB Tricks and was starting to publish works that if used improperly can wreak havoc with Radio communication in general - as not as specifically spurious or harmonic, but as a method of intentional interference if used improperly and not understood.
DISCLAIMER:
If you feel that it would be necessary to delete any more of the posts as I explain my reasoning's, then I will no longer participate in an environment that becomes exclusive to it's members and censors it's own...
