What would cause 2 transistors (out of eight) in TS 1600 to blow? Both are on the same board. The other transistors on the other board that shares the combiner is OK.
The 10-ohm` base bias resistors are not burnt, the amp was not driven with more than 30 watts.
The transistors are open from C to E and from B to E
I did in-depth testing of capacitor and resistance values of the components on both boards (nothing out of line)
What would blow 2 transistors on the same board and not the rest?
