Ok I'm finally gonna hang the dipole. Here's my questions. I basically want to use it for local transciveing. Which I learned from all your help that stringing it vertically is ideal. Im gonna string it from a tree in my yard. This is where the problem comes in. The highest branch is about 21ft. So the dipole being 18ft would only be about 1 to 2ft off the ground. On the other hand there is another branch about the same hight as the pre mentioned 21ft. Thats about 30ft away from the the first branch. Would I be better off stringing it horizontaly. In the case of it being horizontal it would be 21ft off the ground. Verticaly the top 9ft half of the dipole would reach from the feed to the branch. The bottom half from the feed to the ground. I will be using a sonar 2340 with about 300-500 watts. So what are the advantages and or disadvantages if any on vertical or horizontal?TThanks again good people.
