Click here to find out how to win free radios from Retevis!
you cant use fm on cb or hf for that matter, it excedes bandwith limitations set by the fcc. uhf/ vhf useage is most common. police use fm, as well as 2m operators.
The range on FM isn't significantly different from the range on any other mode. FM has a greater bandwidth, however, which is why it's used mostly on VHF and above.
There's a narrow area at the high end of ten meters where FM is sometimes heard (I operate there once in a while just to see that my rig still works in that mode).
