Recently acquired a used Uniden 880 and a Uniden 980SSB. 880 came with a mag mount 52" stainless whip that reads over 3 SWR through an Astatic PDC2 meter using a 2' jumper of RG8 from the TX on both radios.
Purchased a used Wilson Silverload and mounted to the mag mount which at initial install tested good through onboard diagnostic on the 980 with 1.4 SWR (same result on 880). A few days later took the SWR meter out of the loop and went straight to the 980, antenna failed diagnostic and went over 3 SWR. Same response on 880. What gives? What am I missing?
It may be pertinent to know that the antenna is sitting on the floor inside a window of an upstairs room. Coax is run along the walls with no coils. Yes I understand that will not TX well for lack of ground plane, but believe I should be able to tune and get a decent SWR for RX until I can get a better antenna for my situation.
(Maco V58 is due to arrive tomorrow) .............
