Ford Truck NOISE
EDUK8TR
I went to Rat-Shack and bought a noise suppression kit and installed it. Worked for me.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
Wayne C.
CDX-787
mobile/base
Magna Force 900
HR2600/Kenwood TS-430S
MR. COILY Single Coil/Wolf .64 ground plane
D104M6B/MC-60 desk
Every man is a damn fool for at least 5 minutes every day; wisdom consists in not exceeding the limit.
</p>
Wayne C.
CDX-787
mobile/base
Magna Force 900
D104M6B/MC-60 desk
</p>
Ridgrider, you need to sell that Ford!!!<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek">
I've got a '90 Ford p/up and the noise is unbearable. I've gotten rid of some of the noise by doing alot of grounding to frame - anetenna mount to frame, hood to frame, doors to frame, alternator to frame, many grounds from fuel tank to frame, etc... The worst culprit for noise in my truck is the fuel pump (which is inside the fuel tank). You can tell if the noise is coming in through the antenna by disconnecting the antenna with engine running and cb on. If your noise stops when antenna is removed the noise is coming in through antenna, if the noise remains with antenna off you can buy a filter for your cb power wire which will eliminate much of the noise.
PS, try and find the source of the noise then post what you've found.
Hossless
</p>
Hossless
</p>
ANYONE KNOW THE BEST WAYS TO GET RID OF THE NOISE GENERATED BY THE COMPUTER AND ALTERNATOR ON A '98 F-150???<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/alien.gif ALT="0]">
</p>
</p>
Hey Shockwave, that was great! I'm gonna' have to try that. All the grounding I did "helped", but did NOT eliminate enough of the fuel pump noise. Unfortunately I couldn't get the pictures to come up. Off to RatShack for some snap on rf chokes.<img src=http://users.joplin.com/dutch64804/posticon36.gif ALT=":36">
Thanks, Hossless
</p>
Thanks, Hossless
</p>
    Greg T has left the room.
