I just got another export radio, too: Anytone AT-5555 V6. This one is much larger and all-mode: AM, FM, CW, USB, LSB. Out of the box it covers 10M 28.000-29.700 in 5 kc steps, all the way down to 10 Hz steps using the RIT/XIT (tx/rx clarifier). Six banks of 60 channels each. It does splits too, so repeater use is possible. Doesn't have PL tones as far as I can tell, but tone boards are available that you can add to any radio. There's plenty of room inside for one. I have at least one and probably more of those kicking around here somewhere, so I may just add one.
A power-up sequence toggles between 10M and "export" mode. That gives 6 banks of 40 channels in the same plan that some of the other export radios use, up to 28.315 MHz. RIT/XIT works the same way here, down to 10 Hz steps. So there are really no skipped channels; or rather there is a workaround for any skipped channels on the main dial. This also means that the ham can access the bottom 15 kc of the 10M SSB subband without having to do the power up dance, just to see if there is activity.
But wait; there's more! If you get the programming cable (I have one on the way and have already downloaded the software), you can set up 60 channels in each of the 6 banks, covering the range of 25.615 to 30.105 MHz. You can also add splits to any of those channels. So, you could put all of the CB channels, plus all the A channels and the most popular freeband channels (27.555, 525, 465 etc.) in one bank. All of the lowband FM business freqs within its range in another. Never know what you might hear there. Then dedicate the rest of the banks to 10M including the entire CW/digi/beacon/SSB subbands in 5 kc steps, plus all the discrete AM and FM channels (hams don't call them channels but that's what they are) including all of the FM repeater slots.
That makes for a very useful radio.
