Welcome!
Sirio Performer 5000 3/8 is where I’d start from scratch today. Contributor
fourstringburn has a thread on testing that on a Volvo with a bird perch mirror door-mount bolt. A driver knowledgeable both about big truck mobile AND more demanding ham radio installations.
Longest antenna always seems desirable.
I’d rather have mirror mount base brackets than these cab roof factory pieces on assigned 579 Pete.
Cophase worth it to me, but not everyone would agree.
No matter whether a base station antenna or mobile, SIRIO gets a lot of attention around here.
SKIPSHOOTER for big truck mobile: I’d have a spare pair in any big truck in the unlikely event they weren’t the best choice to begin with. Low price & American-manufacture. (“natural” color recommended). A PVC tube capped at one end to store.
Per your question I’d buy both sets.
The mount itself, RF bonding, etc look to this clicky for the mobile install guru:
www.K0BG.com
This is the make-or-break stuff. Fine gear won’t overcome a bad installation.
Bad installation = normal practice in trucker-land.
AM/SSB is the other
minimum I’d stress having in a radio. Leaving out 11-Meter Sideband makes no sense given that there may be a day that XL-range is badly wanted.
A Uniden 980 AM/SSB plus an RM Italy KL-203 75W amp will outperform most so-called big radios. Again, a backup I’d carry with me (Harbor Freight Apache 2800 or 3800 transport case). $200 for the pair.
I also highly recommend the
WEST MOUNTAIN RADIO CLEARSPEAKER
as it gives these CBs what ham radio features: digital cleanup of the audio signal. (DSP). Ones radio is better than suspected. While a unit of the same type can be installed in the path to another external speaker, mine has traveled 250k including oilfield work.
Wouldn’t be without it. (Threads to read).
This little box from DX ENGINEERING is how I’ve used Anderson PowerPoles to connect my cables from BATT up to the overhead to run the radio, speaker and baby amp.
The Uniden 980 plus baby amp and the ClrSpkr is better than than $500 worth of truckstop tweaked gear for the same money.
Ever had Squelch closed and RF Gain wide-open. Dead-quiet . . . then had to back it down because of TOO MUCH local conversation? Ha!
A big radio benefits just as much from the ClrSpkr. I’m running a GALAXY 99v2 this trip.
Plan the mobile install according to the K0BG link. Radio & antenna are last.
Ferrites on all coax & power has also been a help (PALOMAR ENGINEERS). See threads on
mobile coax chokes.
Finding someone with an antenna analyzer is the near last step. A few install detail changes may be necessary. Then a re-check. SWR checks are a long way from being enough.
It is distinct fun to talk with someone the guys you’re running with can’t hear.
I’ve been doing it for years. The Interstate closed 25-miles ahead and YOU know it ten miles before the others. Etc.
M0GVZ a contributor here from Britain drives big trucks. Great posts.
Other truckers here as well. Digging around this place is a great way to spend some wait time OTR.
(Thumbnail of snap-on ferrite on mic cord)
Take your time on the details and OLD SCHOOL COE will have them shaking fists at you.
Large Car ain’t #%*+
