FS Vintage Gray 150 Amp Toogle Switches (BOO Tuned)
70cst
Dec 4, 2009
627
186
53
72
[/IMG]
This is a very nice Gray 150 That BOO went through. I beleive it is still original and very nice looking. (You can verify with BOO) Power will meet if not exceed 150. BOO went through this to verify it performed the way it was designed to do. Payal or check. Buyer pays shipping. $100 1st I take it gets it. Thanks for looking.
DRIVER
DOES ANYONE KNOW IF THIS WOULD BE A DECENT DRIVER.NOT SURE HOW LOW IT WILL KEY.NEED IT DOWN TO AROUND 8-10 WATTS
  • @ Geoexplorer69:
  • @ Geoexplorer69:
