I picked the FT991a, for the reasson both receivers are much the same in sensitivety, just that the 7300 will get blasted in a high signal situation and the D/A converter will overflow and you have to reduce sensitivety to overcome that.
The FT 991 has also better tools to fight qrm/qrn, so when you want to dig out a small signal from the noise the 991A will be better, yes i worked with both of them.
Yes, the display on the 7300 is nicer, but i did not buy tthe 991 A for the display but for having the edge on reciever and noise fighting tools.
Running digital modes all day now, doesn't give a peep about running 50 watts for 9 hours long.
Further the 7300 has an overshoot, meaning when you go from transmit to recieve the 7300 will produce rf to the amplifier if you use one that already has dropped back to recieve through the ptt line.
You can get large rf sparks on the relay in the amp, burning it out, or damage the amp its self.
The 991 A does not have that problem, my Heathkit SB-1000 is perfectly happy with it.
In the end it is best ( like i did) to work with both recievers the 991 A just sounded better, had a better SSB modulation and the receiver worked better.
In owning the FT 991A i already worked around the world on all continents is both phone and digital.
And i don't have a gigantic antenna farm, just living on the edge of a small city.
Your money, your choice to make..
Both have their merits, the 7300 is cheaper, lacks 2 and 70 all mode as well.
It's display is a small bit larger, 3/4 of an inch.
But then i buy transceivers for how they work, not for the nice display.
One of my neighbors who lives 1/2 of a mile from me as the crow flies has an ICOM 7300 & he says he has Zero issues with the frontend & I point right across his Mosley PRO-67-2 with my Mosley TA-53M & I'm running 1200 watts on HF.He also has an ICOM 7800 & he says it has no issues with overload either as I do not with my ICOM 7600 from his signal with his ALPHA 9500 & Legal limit.I'm not a fan of any touch screen radio but that's what my friend says about the frontend on his 7300.He has no issues with his 9700 on VHF either so I guess all of them are not the same?
SIX-SHOOTER
