FT2900E
ahasverus
Dec 2, 2011
70
3
18
dear OM
I use the ft2900 e
When I use the freq tx 145.600 the rx freq jumps to 145.000
also tx 145.800 rx 145.200
and all freq between 145.600 and 145.800
but using tx 145.595 no jump to 144.995
tx 145.805 no jump to 145.205
is this normal
tried to change in menu
(49 to 52) but cannot find the way IF it is possible
thank you for advice
Are you trying to use 145.600 as a SIMPLEX freq? If so your automatic repeater offset is shifting the RX down 600 to hear the repeater...Try looking at the display is there a (-) showing...if so that is the issue...Menu 43 I believe sets that...so it can be turned off...
See page 20-21 of the Op- manual to Enable/Disable auto Offset...
All the Best
Gary/W9FNB
