I thought I'd post this here in case people don't always get over to the Tech Bench section.
A couple of weeks ago I replaced the fuel pump in my Jeep. While I was at it, I decided to work on the fuel pump noise that is VERY annoying on this vehicle. It's so bad that it's a good 2-3 S Units worth of noise at all times. The fix I did was very simple and it eliminated ALL the fuel pump noise from both radios in the Jeep. It's not that hard and it's definately worth the time to do.
I got a big ferrite toroid...the biggest one I had is one that I cut off an old CRT monitor cord. It still wasn't as big as I really needed, but it was a good start. I cut the power lines to the pump fairly close. Took extra wire, wrapping both the pos. and neg. wires through the torroid as many times as I could. For the lower bands, you probably need 10 or so turns, but I could only get about 4 or so through this toroid because the wire guage needed wasn't very small. Since I could only get that few, I used a few snap on beads, as well. On either side of the main choke, I soldered in a .01uF ceramic cap from pos. to neg. Attach the whole thing inline with the pump power line, and presto!! Noise gone.
I hope that helps someone....
