Hey,
Since you can't tell the tone of someone from words on a screen and I didn't want to seem like I was running down the idea (I'm not), I didn't comment, but--
What are you after with full wave elements? Half wave end-fed elements I could understand (though center fed would be much easier to feed), but that won't be a good match to 50 ohm coax.
Are you thinking something along the lines of a reversible ZL special or something? Is the 10' spacing something you just decided on, or is there some specific thing you want to try with that?
Rick
Co phased 1/4 wl would be easiest to make work as far as input impedance.
A Lazy H oriented vertical would achieve what you are looking for as far as a bi directional pattern but it is not steerable.
sounds like you have some good ideas, and it is a lot of fun experimenting.
Max gain will probably be with .625 wl spacing between elements.
How do you plan on mounting the antennas?
A Lazy H oriented vertical would achieve what you are looking for as far as a bi directional pattern but it is not steerable. How do you plan on mounting the antennas?
Your welcome on suggestions.
If you have a small rotor, and want a decent gain light weight yagi.
I really like Moxon antennas, they work and work well for a couple pieces of wire.
