You guys, perhaps, see antennas with these little 'antennas' sticking out under the whip. They are often black, about 5" long, and there are 3 of them in a triangle. CBers sometimes call this thing a "rooster booster", so what is this thing and what does it do?
Sellers claim that it provides a 'ground' plane and "boosts" your signal and it does nothing of the sort. It is actually a "capacity hat". Take a wire and an alligator clip and clip it to your whip. YIKES!~ Your SWR just went thru the roof! This "rooster booster" does nothing but add capacity to the antenna and, in effect makes it LONGER that it should be; IOW, the hat allows you to use less loading coil, thus less resistance. It permits you to use a shorter whip than otherwise would be needed. Loading coils DO introduce resistance into your antenna and, in and of themselves, do not make your signal "better". When it's all said and done, you're better off with a 102" whip. Coils should be used only when physical limitations preclude the use of a 102" whip. SO! When someone tells you those "rooster booster" thingies do something to "boost" your signal, it is smoke and mirrors, horse manure and designed to get you to do one thing----part with your $$. It's kinda like cophasing antennas. Cophase has it's place, but the funniest thing I've seen is a Toyota pickup with two 4' whips sticking on the mirrors, and the owner swears it's "cophased" !
If you want to use one of those "rooster booster" things, it won't hurt a thing (Cocka doo doodle doo!) But it won't make your signal better, either. A "ground" plane is a GROUND
(your vehicle), and anything attached to the whip RADIATES and is PART of the whip itself whether it is a "rooster booster" or a Coca Cola can!
CWM
CWM
