Gainmaster red coax?
Broman
Mar 23, 2013
12
Sweden
A friend of mine is planning to build a gainmaster, and would like to know what kind the red coax is.
Anyone who knows what brand, or where to buy it?
Or some other usefull info?
73´s/ Broman
If you use the search feature on the forum, and type in Gainmaster you will find a wealth of info on the antenna with quite a bit of detail.
There is a ton of info.......
Ok,
Here are Some of the results to be found.
http://www.worldwidedx.com/cb-antennas/103100-1-5-kw-pep-gain-master-modification.html
http://www.worldwidedx.com/cb-antennas/76970-new-antenna-sirio-gain-master.html
http://www.worldwidedx.com/cb-antennas/100493-home-brewing-gain-master.html
Some threads are long, but worth the time to read.
Ok,
http://www.worldwidedx.com/cb-antennas/154485-what-good-5-8-base-antenna-decent-price.html
Yep
    535A has left the room.
  • @ AmericanEagle575:
