galaxy 33
555
424
20
just curious what everyone would think a good amp would be behind this radio
low switch is at 1.5 watts
med switch is at 4 watts
hi switch is at 10 watts
dead key
im thinking something like a 5pill or a 4 pill with 2290s or 1446s
what you guys think
105 amp alternater on blazer
First and simple install choice would be a nice 2 pill with 2879's in it. You could go Davemade, X-Force, AM Power, Fatboy and so on, a Texas Star 350HD would also work.
You could also rune a straight 4 pill from any of then above but with a 105 amp alternator you would be right at the limit.
The only way I would run a 1x4 amplifier with a 105 amp alternator is if get a yellow top Optima battery.
With any of these amps you will not be running your radio on Hi, just low or med.
