Got a Galaxy 33hp2 stuck on one frequency. change bands and channels but still transmits on one frequency. Any ideas?
The PLL is out of alignment somewhere. Or possibly the VCO frequency is off.it’s stuck on 27.495
Not sure if anyone tried messing around with it or not I bought it used. A-d bands it won’t key, e and f it will key that frequency and swing plenty of power. Selector switch isn’t bad
Pin 1 on ic5 has 3.5v on band d, the rest of the bands have around 7.5. Voltage at tp2 channel 1 is 3.4v Channel 40 is 2.9v. Im guessing I have a faulty component causing the low voltage on band dYes, sounds like PLL/VCO problems.
I had a few radios just like this.
to start:
at IC-5 pin-1 check for around 7.5 volts.
check the voltage at TP2 and measure if it changes
when going from CB ch 1 and jumping to ch 40.
check signal at TP3
I’m at work now but I will check when I get home, thanksme drinking some hot strong coffee all early morning here.
but you probably have this:
check the signal freq at TP-3 the PLL OFFSET OSC section.
do you have a signal at IC-5 pin 2 ??
CB ch. 1 should be 2260 kHz
the binary code to IC-5 11100010 (226)
