Galaxy 94hp need a little more
shooterguns
Jul 11, 2005
16
I have a 94hp driving a straight 8 pill. Almost enough. It swings around 125 watts. Is there a mod to get to get a little more? I see some specs on the IRF520 as 60 watt transistor and others say 30 watts.
Adding a handful of watts will make NO DIFFERENCE so why worry about it. If you are running say 1200 watts right now you must DOUBLE your power to add 1/2 of an "S" unit to your signal. If you increase the drive from say 125 to 140 no one you talk to will even notice.
What amplifier are you running ands how are your feeding it?
