Is this what you were referring to?
In the DX979 (DX86v) and all other radios derived/redesigned from the original Cobra148GTL-DX Mark 2 (PB010AB with MC145106 PLL) (1982?) - the AM(FM) RX path does not go through FL3, it goes through FL2, either a 10.695 MHz monolithic crystal filter (narrower bandwidth, looks like a crystal with 3 legs, center leg is ground), or a ceramic 10.7 MHz filter (wider bandwidth, looks like a brown 3 legged chicklet).
SSB RX (and all TX) goes through FL3, the 10.695 MHz square can 4 pole filter marked with 10M4DS or 10M04D that may or may not have the hidden surprise resistor or capacitor underneath (to lower the Q, or widen the bandwidth). But, this filter has NO effect on the AM (or AM/FM) receive section. The 4DS or 04D part of the number refers to them being 4kc wide, or +- 2kc, hence the need to offset the carrier by 2.5kc from center slot, not being 10.4 MHz. When you pass a Carrier Balanced Double Sideband signal from the balanced modulator through this, offsetting by 2.5 kc puts the suppressed carrier 500hz outside of the passband, for better carrier suppression, and the unwanted sideband signal too (even further from the center slot of the filter). So, it will pass up to 4kc of audio, from 500hz to 4.5kc.
Note where the Noise Blanker output clamping transistor is tied into, it works (so/so) in SSB modes, but not so much for AM (or AM/FM).
The reason that the Cobra 148GTL has better rejection is because the receive for both AM and SSB paths go through FT2 (FL046), the 7.8 MHz Monolithic Crystal Filter (crystal with 3 legs as mentioned above). The RX signal then splits off after FT2 and L10, in AM mode, to feed one gate of the Dual Gate MOSFET 2nd Mixer, 3SK45B. This provides better signal isolation from the 1st IF (7.8 MHz) and the injection oscillator (7.345 MHz) to get the resultant 455kc 2nd IF (AM only).
In SSB modes, the receive path goes through the 2SK19 JFET, then to FL3 (FL067), the 6 pole Crystal filter assembly. (Note: a 6 pole filter is better/sharper than a 4 pole.)
Note where the Noise Blanker output clamping transistor is tied into on the C148, it is tied directly to the input of FT2, in all modes. Also, not capacitive coupled like in the Galaxy/Ranger radios. This means it has a direct effect on impulse noises, rather than indirect by capacitive coupling.
