Galaxy receive problems
rance23
Jul 7, 2011
15
This is going to be a little long, but here we go...
I’m having problems with the receive on my radio. It is a Galaxy 949
I almost always have to drive with my squelch turned off if I want to have a conversation for any amounts of time. If someone is right next to me it’s fine but if I am passing someone going the opposite way, about 2 or 3 miles is all I can get. Once they get beyond that then they will start fading in to the background quick. Then I will still be able to hear them just very faint. Then I seems like every once and a while they will sound good for a second.
They can still hear me good & I get plenty of compliments on the sound quality and the distance I am transmitting, but my receive sucks.
Also, during this if I am driving with the squelch off listening to other drivers in the distance & trying to pull them out of the background, the hiss of the radio will get louder & louder. Then after about 5 min or so it will go back quieter to the normal range for a few minutes. It seems that my radio receive is worse during the louder times & better when it goes back to normal.
I hope that all makes sense...:confused1:
I have had it to a radio shop to calibrate the SWR on my antenna. And when I first got my radio I took it there just to give it a checkup.
Has anyone else had of even heard of this?
Please help because I would hate to have to take down my Galaxy and put back up my Cobra 25. Maybe I should put in my 25 to rule out the radio.
Take the radio to a shop that has the equipment to align the receiver. Probably needs a full alignment, which will include the PLL section. The 949 is a Lite version of the 959, both are fine radios. The receive on these radios are outstanding if they are aligned properly.
So just tell them i need a full alignment & including the PLL section. What do you mean by PLL
'PLL' stands for 'Phase Locked Loop'. It is the portion of the radio that is responsible for freq alignment and voltage. It uses a chip and a crystal to synthesize freq's; that's the first stage. It is also the very first part of the alignment process too. If the PLL adjustments are off; then the receive and transmit can suffer.
A full alignment will ensure that everything is set up to snuff. All of the Galaxy radios I have aligned needed it. Some more than others. They worked far better after everything was brought back into spec's. Any radio will - for that matter. Done a few 959's and 99V's. Nice radios when aligned.
However, the SSB mode is susceptible to 'drifting' off freq when the radio is in a cold environment - or if it has just been turned on. Despite this flaw, I use a 99V in my mobile. I like the receive and the audio this radio has provided me for the past 3 years and counting.
galaxy rec
those guys are right when i got my 949 the techb told me he had to start at the pll and work out. because i had almost 0 recieve before it got tuned
  • @ W4KVW:
  • @ W4KVW:
