its a regular jpole booty, those boys are crazy and just refuse to learn, they see gary as some which doctor who discovered how to makee a regular jpole make 9db gain,
their method of testing is totally flawed, he even posted a link to the site where gary got the jpole info from and claimed that was proof it can be done,
i pointed out that the article says you need colinear stacked sections to get close to 9db but he cant even read a simple article whuich he posted as proof,
it is a regular jpole 1/2wave over 1/4wave feed section, just like a slimjim some folk think they have huge gain over other antennas, they dont but they can have a lower angle of radiation than an endfed or groundplane that is not installed correctly, meaning one that is electrically connected to a conductive mast or one with a ground wire running down the pole or unchoked coax feeding it for those nice common mode currents to flow on and ruin your antennas pattern,
99% of people using groundplanes and endfeds like imax are not getting even close to the pattern they should be getting because of all the mis info on how to install and ground antennas floating around on the www,
when compared to such a poorly installed antenna i dont dispute they are seeing what they believe to be 9db gain, they are not alone,
i dont doubt it could beat a 10k clamped to a 25ft conductive mast but 9db gain over a correctly installed groundplane, not while ever i have a hole in my arse.
