Has anyone here had any experience with the GE superbase ?, I am trying to figure out why it won't work with a PLLO2AG installed, It works perfectly fine with the PLLO2A, Now this is the part i find bizarre, If i install a PLLO2AG and ground F.S it will then work normally [26.965 to 27.405 in 10kc steps]
In any other Cybernet grounding FS will shift frequencies down and channel switch will be in 5kc steps, But not the GE superbase
Is there something different in the GE that doesn't allow the PLLO2AG to work correctly ?
