Hi Everyone,
So I made a slight change to my process in that I added a bench radio (Ham) to assist with the overall results. The ham radio (AM, USB and LSB) is dead on (TX and RX) as verified by on air testing.
I am working on a Uniden Grant XL recapped, no mods and all functions work. The radio has been on for 24 hours. I first went through the PLL/Oscillator alignment . The last step is the TX offset I set the TX based on the reading from the antenna jack, single tone in LSB. When I switch to USB to verify the TX frequency its off by 68Hz. I tweak the USB coil (L58) to get it dead on. I then use the bench radio and TX on LSB and USB. LSB is crystal clear but USB is not so clear. I TX from the Grant and the bench radio receive is crystal clear on both LSB and USB.
The challenge is that if I adjust L58 for a clear receive it make the TX off. Because this radio has only 1 TX offset it does not have the capability of off-setting USB and LSB independantly. How do you correct this? How was this correct from the factory?
I am assuming that many radios have the same challenge. Because no one I know talks on 11 meter USB it never really crossed my mind.
Thanks!!
Thanks!!
