what are the currents shown in the eznec tables?, im guessing they are antenna mode currents since there's only one current log, how do transmissionline mode currents figure into the nec logs?,
we know from the arrl article that the impedance of the transmissionline formed by the radials and central monopole is seen in parallel with the antenna mode impedance of the central monopole and that currents flow in transmissionline mode according to the impedance of the 1/4wave transmissionline,
i don't see those currents in the nec logs or current plot but i see them in cst, currents travelling opposite directions/phase on the same conductor if im understanding the plot correctly,
i don't know of another mode of radiation that the sigma could use other than how the arrl describes the open sleeve antena operates,
the tapered cone been wide at the top and high impedance MAY enhance radiation over a parallel sleeve with a smaller spacing due to the larger impedance imbalance at the top of the sleeve,
if anybody can come up with an alternative mechanism for the in phase radiation
from the sleeve im all ears?
Bob, you ask; "what are the currents shown in the eznec tables?, im guessing they are antenna mode currents since there's only one current log, how do transmissionline mode currents figure into the nec logs?,"
What I say here are not facts, it is my idea of what I see and have been able to figure out, right or wrong, on my own.
I asked GHZ24 to join in because I saw a pattern of a model he did in his profile. I stated my intentions in the beginning of this thread.
I'll say this again. For a while now I have sought out someone to talk with about this issue of Eznec currents or currents in general. I've talked to Henry, I've talked to Donald, I tried to talk to Roy Lewallen, but I was thrown in the Brier patch at first mention of the words, "...could you help me a little." I've read as much Cebik stuff as I could, trying to find something specific on how we should view the currents noted on the tabular currents log...but I find zero information.
So, I do what looks right to me, right or wrong in this regard.
Before I posted this thread I determined the models that I wished to compare. The two models are set at 32' feet to the feed points, and I choose my Sigma4 and the New Vector 4000, for this project.
I used my best models for my Sigma4 and my New Vector 4000. I studied these two and tried my best to get them as close to the specs in their manuals as possible. For the New Vector 4000, I think I used your posted dimensions for the New Vector. Then I attempted to get all the Eznec settings, segment counts, source information as close together as I could. I also made sure the segments for the radials and the radiator were as close to the same as possible.
During the process I noticed that the Vector was not resonant where it should at the dimensions you posted and I re-checked the exhibit that you and a buddy did for the forum some time back. I did it right, according to your numbers, so I decided to use the dimension information that I had previously received from some body else. He gave me the overall height only, and I had to try and back into the tubing lengths. A little before you posted you numbers I posted my estimate as to the tapered lengths. Now the antenna shows to be resonant. I could not figure out how I messed up, but I got it straight. I probably screwed up somewhere on your image, and the dimensions ended up too long. I only found this out yesterday or the day before. This is not the only thing I discovered about my old Vector model that caused me to do the project over completely.
After I did these models I noticed that the NV4 model used tapper and the specified length and diameter for all tubing was skewing the model like it did with my Sigma4 model a year or two back. So, I made the NV4 radiator into a single wire a little thinner than I used on my S4. I also had my Sigma4 set that way at one point, but I changed that in light of the ideas I learned from a tip in a Cebik report...that talked about Eznec not handling tapper correctly. I now tend to agree, but I just forgot to change my New Vector.
I think understanding the currents noted by Eznec are vital to understanding how any of these models work if we really want to explain that process in some detail, but without help and advice that is not easy, and I surely could be mistaken. I'm sure Donald will be glad to hear that bit of testimony from me.
I had to redo all of my models, so I'll post them maybe tomorrow. I want to study them and try and make some notes to help describe what I see in the tabular currents log and how they relate to the elements in the antenna.
I do not know how currents actually work in Eznec. I assume that is part of the process that Method of Moments software handles. Personally, I don't even think that Eznec is involved in the computations at that level, but I really can't say for sure.
Personally I have the idea that the Sigma4, design being referenced as a coaxial J-pole by Sirio is probably pretty accurate. I think the up swept radials do for this antenna just like Jack use to tell us about the Sigma...those radials act like and extension of the feed line using cancellation of the currents flowing on the radiator and the radials, being parallel, pretty much out of phase, and with almost equal current magnitudes flowing. I have since added my own thinking to the ultimate conclusion in order to agree with the notion that this antenna radiates from top to bottom for the most part.
This idea relates to how I see cancellation working when the elements are not perfectly balanced and there is some difference in the currents. Where most of the currents are canceled out with the primary current phase either contributing to the top element if in phase, or else the currents are a bit destructive for the pattern if out of phase with the top 1/2 wave element.
For me what happens is we see something similar to common mode currents or antenna currents develop, or depending on the phase we could see transmission line currents, that don't radiate well.
Whatever the phase for the strongest current is after cancellation occurs, I call it the difference for lack of a better term, is what determines the addition or the subtraction that result...showing up in gain.
Bob maybe I can figure out a way to show arrows like EzBob Antenna Software does it, who knows?
BTW, I have never said the cone does not contribute to this antenna's functions. Without this function from the radials, in this case, we see a typical 3/4 wl radiator with RF at very high angles, and even a j-pole doesn't act that bad. What I say is this bottom area is a matching device and due to its large size effectively raises the primary radiating element up higher than the typical 1/4, 1/2, or 5/8 wave antennas when these antennas are mounted at the same feed point heights. Frankly this will get you where it hurts Bob, this idea sounds exactly like our old nemesis the Masterbater.
Bob, the two models below are my evidence, trying to explain why I claim the Sigma4 primarily benefits from being taller when mounted at the same feed points with other antennas. IMO it does not project a collinear effects like we would see with a true collinear design.
The Starduster and the Vector that are attached below are at the same height at the bottoms for both antennas noted. Does the SD'r also develop a collinear feature as well? Here we see the Vector is still about 8' feet higher at the tip, but the bottoms are both at the same height. I see this all the time, if you guys don't...then you just did something wrong is the way I see it.
I know this may seem silly to you and Donald and maybe to a lot of others, but this is why I have these ideas. I would have never known if I was not able to model. I have also claimed the same thing going on in the real word testing I have done for years too. I have even produced videos demonstrating this work, but I understand your disbelief.
I also agree with Sirio's description that the Sigma4, is a coaxial j-pole of sorts, but it works a whole lot better maybe. How do you guys get around this fact that all that know or care what is going on here is an in your face fact that nobody can argue...unless your minds just decide to ignore this simple fact...that Sirio describes the antenna they designed and build in a way that you and Donald refuse to accept. What does that say about being single minded? I that anymore bizarre than my idea?
My main idea here is that the Vector is coaxial, but not so much of a J-pole maybe. Bob, I think the sleeved idea you posted is also a good and clear demonstration of what is going on with the idea you have developed for this complex antenna, but you guys just didn't test the math the article presents as an important tipping point at 3.2:1 ratio. This is what the project I'm in the process of completing is hoping to demonstrate here, but I could be surprised and find that I am wrong too.
The attached two models show me that if you raise the Starduster up even close to the tip height of the Vector...the results noted for the models is not so dramatically different as everyone imagines. As noted above, I see this in my real world testing also, but some don't believe me in my words or my videos either.
View attachment Starduster vs. Vector.pdf
I will study more on these models I designed around the math ideas in the ARRL article I noted above, and I'll try and demonstrate what the currents log shows me. Hopefully I will see what I expect when I finish and make a recap. If you don't hear me talking to myself again about this topic, then just figure that things did not pan out for my ideas, and I've gone on to other subjects.
I would post the work for this project, but it will be a big file and no body would understand anyway. I might try and make notations and send it to you Bob, maybe I can do a better job of explaining to you.
The other day I was hopeful that GHZ24 and I could talk about this and get somewhere, but I think he is probably long gone by now. Who in their right mind would wish to get all snared up in this fruitless discussion...where only pride and animus is the result.
This is not personal Bob, this was only about my opinions and ideas. I put it out there for the consideration by others only. If it is not somehow convincing, then I just did a bad job of trying to explain that idea.
I do appreciate you questions.
