Hello,
If you can provide the present element lenght and diameters(over which length)/distances...
Im sure there will be some one who can put your antenna in some software and get some results.
In aspect to more boom length.
Boom length equals gain.
It would be fair to say You can expect a advantege in gain.
The "standard" rule is: if you double the boom length you "gain" 3dB.
Often it is true, that if you "add" something at one point there is a drop somewhere else.
However, your original boomlength is....well...
I think i have designed at least 100 different 5elements yagi's, but never on such a short boom length.
Your doubts conserning the boom length is one that i share.
16 feet seems indeed rather "short" for a 5elements.
Im not saying it cant be done, but i am quite confident one can get the same or better results with only 4 elements.
Most "owa" designs (pse google owa yagi antenna to find out what it indicates)
have a boom slighlty longer...say around 18 feet.
And owa designs are also known for having a relative short boom.
Your idee to extend the boom to say 24 feet is certainly advisable.
Not only will be the gain be improved but this kind of lenghts are often used and have provided "good" overall performance from a 5el.
So, all in one...yes go for it! but one who migth help you needs to have dimensions and lengths to "optimize" your system.
Kind regards,
Henry HPSD
19SD348
www-dx-antennas.com
