Grampa and Homer hooked up this AM
Marconi
Honorary Member Silent Key
I Support WorldwideDX.com!
Oct 23, 2005
7,235
2,387
343
Houston
Homer was using his new end fed 1/2 wave and he sounded like he was a neighbor. I was working my Starduster.
It was great to talk to you via DX today, Marconi. Your station was doing a fine job into NW Arkansas. The Starduster on your end, and the homebrew end fed 1/2 wave seemed to like each other, alright.
We'll have to do it again soon.
Yep, my old Starduster has been up for a year now and is gettin' real good and seasoned in by now.
I typically can't tell if I'm on my Starduster or my Gain Master, and the old SD'r is about 7' feet lower at the tip. The SD'r is not much, but is still notably quieter when conditions are real good and quiet.
I should have done a switch to the GM to see if you could see any difference with its big 5/8 wave advantage, but maybe next time.
Homer your antenna was showing me a S7+ signal, so conditions were good for me too. If I had my pre-amp on you would have been hitting me with an S9+ signal.
I just got thru talking to WR #11, Robb, in California on his beam and he was coming this way great...especially toward the end of the contact. I think California was just starting to come this way and was in the Houston area for about 30 minutes, and then my big time DX just went away.
Robb that radio was sounding just fine to me. It didn't sound like a Kenwood etc, but it was perfectly readable and clear. I was working my Starduster with 60 watts.
Yeah, I was using the RCI-2995 DX that I just got back from the Ranger Authorized Repair Center in Ramona CA. The mic was an old Turner+3 that I got for $10 (had to fix it) from the local hamfest last week. Thanks again for that DX radio check, Marconi!
