Please, do not turn this into a "does the GPK work or not" thread. It's not intended for that. It more of a question of which GPK might yield better results.
I currently have an I-Max antenna mounted on a 20' mast that runs up the side of the house from the ground. The base of the antenna clears the peak of the roof by ~5-feet.
From what I've read, there are the following GPK's available.
-- I-Max GPK.
-- Antron-99 GPK.
-- Maco Boomer GPK.
I believe the 1st two are fiberglass to match the antenna and the third is aluminum. The 1st two angle down by some degree and the third are straight elements that extend horizontally.
Based on the antenna that I have and the laws of how ground planes work, which of these may have the best chance of performing when installed?
-- I-Max GPK.
-- Antron-99 GPK.
-- Maco Boomer GPK.
