Nope. No way to release them when you want to crank the tower back down. When working on them you are supposed to crank them down and then block them with a 2x4 thru the cross members to prevent them from becoming a guillotine.
How do the safety latches retract when cranking down? I know the ratchet and pawl system on the crank has a safety to prevent free wheeling if you should let go of the handle.Some have a worm drive which is even better.
So it is an aftermarket add-on then. I could be wrong but as far as I know there is no such device on factory towers. I wonder how he activated the top latches at sixty feet up.
2foot elf climbed up and eng7ged it
★☆ Sent from Xoom☆★
I like the concept of crank up towers, but I would probably go with a Hazer instead. I also like the tubular crank up towers as well.
