Hardline coax-feedline
  • Thread starter Icom 706 King Cobra
  • Start date
I
Icom 706 King Cobra
Guest
hello all,
i have been a little busy of late..
anyway i got my 12 element 1.25 meter & dual polarity 9 element 2 meter antenna..plus will rearrange my 16 element for 70cm..
so since i am going to put these up & due to the frequency's
and we all know loss adds up quickly there..
i will finally get to installing my Andrews Heliax LDF5-50A..
so any of you who are familiar in using this stuff...
is it really needed to go & get the specific prep tools to put the ends on...
what do you think...
Thanks
KC2MLZ - Bob
</p>
That would depend.How handy are you? I have installed many connectors on LDF4-50 half inch heliax and also on LDF7-50 the 1 5/8 stuff and one on 3 inch heliax.Now that was a real pain.All you really need is a sharp knife,fine toothed hack saw,ruler or tape measure,and a high powered soldering gun for the center piece.A small file to get rid of the burrs is good also.I think the center is soldered like the LDF4-50 is.The bigger stuff is all pressure fit and clamped.There are installation tools and reemers made to do it and they do make it a bit easier but they are not 100% necessary.Have fun.I know I did with the three runs of LDF4-50 I have for 2m,6m and a tribander 10-20m.<img src=http://users.joplin.com/dutch64804/goodluck.gif ALT=":good">
Garth 9VE01 PE993 CDX993 Learn from others mistakes.You can not live long enough to make them all yourself.</p>
It would depend what type and model number of fitting you are installing.Andrew should have the installation instruction on their website.I only ever installed the big 1 5/8 or 3 inch EIA connectors with a "bullet" and flange connector.Try www.andrew.com and look for your connector number.<img src=http://users.joplin.com/dutch64804/goodluck.gif ALT=":good">
    535A has left the room.
  • @ AmericanEagle575:
