BALUN KIT
Has anybody here ever tried one of these with/without success? I'd like to use one of these instead of an open air choke balun on a direct feed quad install. Any opinions?
First, it isn't a balun at all, it's a choke made using ferrite instead of coils of coax. Second, there is no such thing as a "one size fit's all" ferrite choke usable from 160 to 2 meters. That's especially true for absolutely any mix of ferrite if only 9 inches of coax is required to hold all the ferrite cores required for effective 'choking' at any frequency between 160 and 2 meters.
Strictly speaking, Palomar isn't lying in their ad, but they are definitely NOT telling the whole truth about using ferrite cores for 'choking' off CMCs. There's been more than one study of this sort of thing done. All of them show that there are varying degrees of attenuation depending on the size, type, and the number of 'passes' of a conductor through a ferrite core. While ferrite will attenuate CMCs, there are other methods that can be more effective for given situations. (A bicycle can certainly be an effective way of getting around, but makes a terrible way to move a loaded semi trailer! About the same difference here. That's an exaggeration, but not a very big one.)
I'm only looking to control CMC without adding a ton of attenuation.I'd like to use one of these instead of an open air choke balun
I will be feeding direct with a 75ohm matching cable.on a direct feed quad install.
BALUN KIT
My bad, it's the 4 element version HERE.
It's still in the box, I just want to only have to handle this thing as little as possible and cover all bases before hand. And I'm only looking for opinions on CMC suppression, not matching networks etc..
Nobody is upset, I can assure you. I planned on using the 75ohm matching cable instead of the matching transformer which limits power handling and bandwidth. If that's not optimum, I have no problem listening.So, don't let questions get you all upset.
I started this because I have an open air choke that I made for my M103, but for now I'd like some input on these "sleeve baluns" or "sleeve chokes" or whatever you want to call them. I had the wound choke mounted on the boom, directly feeding the gamma on my M103, but I don't see a decent way to mount it on the quad. It could be placed between the matching cable and feedline, but a 1/4 wave won't get it down the mast, hence my curiosity in these "kits" from Palomar-Engineers. This would make a very clean install, IF they work.
But I don't even have a Signal Engineering antennaWe can talk about sleeve baluns/chokes, but I can't see how that would apply unless we make some assumptions about the matching device that Signal Engineering uses for their dual polarity White Lightning Quad maybe.
I'm out of town until Sun/Mon but can take some pics then.Can you give us some close up pictures of the parts you note above? That may be helpful to describe better what the 75 ohm matching cable and the matching transformer is in your mind.
Thanks WR, I've just got a few PIECES stuffed in the attic of my home, but I can't limit myself to 1.5kw ......... well, I could, but I might come across a nice 11m tuber tooKeep in mind it is rated at 1.5KW SSB not CW or AM, so if you intend to use excessive power ( do not ask me to define excessive power) you will need a balun that will fit the need.
