Hello everyone, time for some newbie questions....
S
SlikSak
Guest
Here is my current set up: A Cobra Classic 29 LTD with a "102 steel whip antenna. I am going to send my radio to best communications for their 50 watt tune up and plan on adding a 450 watt amp. Will the antenna I have now suffice or do I need to replace it with something else? Thanks in advance!!!
</p>
Welcome!
The 102" whip is great, you can't do much better, (especially if you're sitting still). The only draw back with the 102" whip is - it "whips" and bends like crazy going down the road. This will effect your swr and maybe your signal a bit. If you have the funds, I'd definitely go with one of Kale's - Predator 10k antennas, you won't be dissapointed.
Good luck, Hossless
PS, let us know how you like the FGbest 50 watt tune up, and if it measures up.
</p>
    535A has left the room.
  • @ AmericanEagle575:
