Hello from Chadiza, Zambia.
I am a U.S. Peace Corps volunteer working, among other things, on trying to teach skills that can lead to sustainable development. One of the big challenges, especially rural areas of the country where I am based, is the lack of resources for doing research. There are few books and these books are out dated so the internet is the option with the biggest 'bang for the buck'. However, the fact that it provides the largest amount of information for the lowest cost does not mean that there are cheap options available. Unlike in the states where DSL is almost ubiquitous, for most places in Zambia, the only means of connection are cellular or satellite, both of which are costly to use in a school setting. There is also the problem that, except for the limited use of small solar panels, electricity is not available apart from district centers and the few cities. Therefore if there is to be any means of connectivity in rural villages so that teachers can research information for their classes and business people or farmers can get prices for seed, fertilizer and the going rate for their products, it will have to be done via a low cost, low power option.
As a result, I am looking into amateur radio as an option. Before coming to Zambia, I knew very little about radio communications. Although I have learned a small amount more about the field I by no means could build a transceiver that could connect to the outside world, nor do I have a license to do so. Therefore I am looking for more information on radio regulations and licensing to be a ham radio operator in Zambia Supposedly there is an organization called Radio Society of Zambia that is an amateur radio organization, but I have only found outdated contact information for which neither the email address nor the phone # work. If anyone has contact information for a ham operator in Zambia, please let me know. Thank you for any information you can provide.
Oh, I found a good .pdf book today that I am reading now, after many frustrating days spend trying to find online resources with limited connectivity. It is not really like you can just go to your nearest library and to order a book and have it send here would take months. The link is below:
Ham Radio For Dummies - ON8WW
Anyone considering applying for a Zambia license should probably first write to the society. They are very helpful:
The license bureau:
  • The Communications Authority
    Office of the Controller
    PO Box 36871
    Lusaka, Zambia
KB0KVA also invites anyone having problems or questions to contact him at 314-962-2730. He is a member of the Radio Society of Zambia. Equipment may be kept at port of entry unless you have a document from the PTC which allows you to bring the equipment into the country.
The above is a cut-and-paste from the information available from the ARRL (American Radio Relay League). Good luck.
Ham Radio is a useful route to pursue, but you are looking for internet access for rural schools.
You should know that 2.4GHz wifi is capable of long distances.
High gain yagi antennas are readily available for wifi frequencies.
In addition, there are so many choices of wireless mesh routing protocols.
The list of ad-hoc wireless routing protocols is lengthy.
But I would think there is something there to satisfy your requirements.
1 watt amplifiers are readily available for WiFi, and laws regarding such devices may not be regulated in your country.
Perhaps Lusaka is too far for you to get internet from, but instead Malawi is probably your better choice.
First a clarification on my last post, when I said: "That is the contact information that does not work" I was referring to the Radio Society of Zambia one, I sent and email to the contact you gave me yesterday but he has yet to respond.
In response to the last response, there are several reasons I am interested in pursuing amateur radio as opposed to other ways. First, I think it would be a very good project for the schools I am working through to take on. Second, even if we could use conventional Wi-Fi to connect to the capital of Malawi, this would still probably require us to spend more money then is available in subscribing to a DSL connection in Lilongwe as internet in Zambia (and I assume Malawi) is 5-30 times more expensive then in the states. However I remember having heard that Malawi is trying to role out internet connectivity for many of it's schools, so I will look into that to see how they are attempting to achieve this and whether it would be possible to work something out where Eastern Province in Zambia could join on board. The only problem is I suspect that they are going the satellite connectivity approach which would not be that easily extendable. I will read about the Yagi antenna though. Thanks
  • @ Geoexplorer69:
  • @ Geoexplorer69:
