Help Identifying Unit.
Aug 17, 2019
2
2
13
61
I picked up a Browning Golden Eagle Iii and it came with what appears to be an amp. Is this just a home built amp? Design is very similar to the Browning receiver and transmitter but not quite. Haven't taken off the bottom yet, top side only has 2 tubes.IMG_2149.jpg IMG_2152.jpg
The identity of the two tubes is a big deal. Good chance that one of them is a 6AQ5. Its only job is to sense the radio's carrier and activate the relay.
The other tube will be a slightly-larger 6BQ5 or 7189 (same thing) if it's a JB-12. Won't see much more than 30 or at best 40 Watt peaks. Only lasts very long with the carrier control on the rear turned down to 3 Watts or less.
The other possibility is the JB-150, using a larger tube like 8417. It's bigger, tends to get you 100 Watt peaks or more. Can tolerate up to about 5 Watts of carrier.
They're popular as drivers, since they allow you to reduce the carrier level while maintaining high modulated peak power. Typical nickname for one of these is a "modulator", even though the textbook meaning of that word is something altogether different.
And if it contains 40 year-old electrolytic caps, they should get changed before they release any magic smoke from the other parts inside.
The fuse found in these is usually sufficient to prevent it from burning down your house. But the size used by the factory won't protect it from being run too hard for too long.
Enjoy it while it lasts.
Thank you both! It has an 8417 tube in it so based on what you posted it’s most likely a 150. Taking bottom off tonight to see if there is any damage there. Surprisingly, the Golden Eagle r68/t68 for as bad of shape as they appeared to be work. I did replace the 10amp fuses with correct 2amp before hand.
Reactions: Holydvr and NZ8N
  • @ Geoexplorer69:
  • @ Geoexplorer69:
