Help me identify this board?
RStephen
Sep 8, 2011
Greetings,
:headbang
I recently acquired a SuperStar 3900 for free out of a wrecked semi. I know truckers are notorious for Mod's and do not know if any have been done to this radio. My intent was to explore available Mod's and then look at radio to see if any had been done to it. This is where the confusion started. After researching available Mod's and viewing a few schematics/board layouts, I now see there were many versions of the 3900. If anyone could look at the below and give me a clue as to which version of the 3900 this radio is I would greatly appreciate it. If anyone can tell from the below any obvious Mod's please let me know. I have noticed one possible Mod. An orange (I think) wire has been cut from J-108 and from J-304. I think these two points were once connected but have no clue why this wire would have been cut.
Thanx....
dont see anything out the ordinary there ,but could use a closer up picture too.there could be mods on the solder side as well.
Looks like a single final ept360014b board or a similar clone. a better pic with fascia pic,rear pic and close up of board rear would make id'ing it a lot easier.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
