So I started assembling my new Maco V58.
I have 1 question...
Is the "Aluminum Bracket R03P Spider" (the Hub the holds the ground radials to the base of the base section) supposed to me Tapped for threads so the 5/16" x 1" Bolt/Nut/lock washer combination that tightens it against the Base section can screw into it?
My Hub is not tapped, and that supplied bolt isn't going to tap that cast aluminum....
HELP!
HELP!
