Here I go again. I found a wire dipole that has a 1:1 Balun ( had it stuck away for several years). I have put it up instead of trying the 102" whip I wrote about earlier. I tried it in an inverted "V" at a 55' angle and 45' angle, tried it horizontal too! I cut it the right length, aprx 8'5" on each side... the swr was over 3 at Channel 40 and around 2.5 at channel 1. I cut off 1 inch, no change, cut off another inch, no change, total cut 3" off with no change. I checked the continuity from side to side on the Balun and it has continuity! On a regular wire I've never seen continuity between the 2 sides (Braid and center conductor) unless there is a short between the sides. Now get this...AT the radio the braid side has no continuity to the center conductor. What the ...is happening here. First can't adjust SWR and now this?? Is this the way a Balun is supposed to work? Before I do another one I have to figure this out...Never used a Balun before (Never knew they existed until I found this. I've forgotten it I suppose). Any help will be appreciated. Thanks, TD
