Hi guys!
Working on a Royce 642 and thanks to @Shummy that shared the service manual my life became much easier. First thing was to fix a bad power switch which was an easy task since the switch is a DPDT and only one pole was used, which was burnt, but the other one was as new.
The TX/RX relay is in bad condition and it has to be replaced, but this relay (Matsushita AW6221) is discontinued. There is a relay though (AW622144) that has same footprint and can be ordered from a small number of distributors, but have any of you replaced this relay with another type that will fit into same layout?
