Hey Klondike Mike
loosecannon
Mar 9, 2006
4,519
4,304
273
this was supposed to be a PM, but i think you need to erase some before you can receive any more.
so, here ya go:
its the same as the list from the 2000 in this link with a few exceptions:
http://www.cbtricks.com/radios/cobra/2000gtl/graphics/cobra_2000gtl_om_part_list.pdf
here are the electrolytic caps that are in the 2000 but NOT in the madison: 218 525 232 230 231 512 217 535 540 542 501 530 214 527 523.
here are the electrolytic caps that are either not in the 2000 or are different values. the values i give are for the madison: C302-220uF, C18-47uF, C304-3300uF,
C205-.47uF, C209-10uF, C212-47uF.
that should be right.
in the old SAMS books, they list the tantalum caps (which dont need to be replaced) in the electrolytic caps section. this can cause some confusion.
take it easy.
electrolytic caps list for Uniden Madison
>>... this was supposed to be a PM, but i think you need to erase some before you can receive any more.
Whats with the PM system on this board? I've barely got any old messages in my mailbox.
>>...its the same as the list from the 2000 in this link with a few exceptions ... here are the electrolytic caps that are in the 2000 but NOT in the madison: 218 525 232 230 231 512 217 535 540 542 501 530 214 527 523.
>>...here are the electrolytic caps that are either not in the 2000 or are different values. the values i give are for the madison: C302-220uF, C18-47uF, C304-3300uF,
C205-.47uF, C209-10uF, C212-47uF. LC
Thanks for the info LC. I'll have to decipher it now. I've already got the 2000 list below;
  • @ Geoexplorer69:
  • @ Geoexplorer69:
