Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
is there any way to filter out the interference i get from my HID headlights on my cb, all other lights are fine, but when i put the HID on, crackle crackle , and nothing else can be heard, what can i use to filter it out???
Try putting a .01uf or .1uf ceramic disc cap across the power leads at the light. You might have to use both or just one of them. You can also wind the power leads around a ferrite torroid, but you'll probably have to extend the power leads to do this.
il give this a try also, thanks, didnt realise the cb would be so sensitive
could you also explain exactly how to instal these caps, just the power lead???? or from live to earth??? and what voltage?
im running it from the battery direct, i have a ferrite block on the power leads. havent twisted it round it though, i know that helps, or could i put a dic cap on the power leads to help sort the interference
With crap HID kit you will get always noise on CB RX.
With Hella or factory Merceses HID's I never had problems.
From Chineese HID kits I had noise in 20m radius.
Mike
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
