I'm sorry for asking so many questions but I'm really stumped with this.
I will admit that I'm not using a good SWR meter, it is a cheap astastic but with it I was able to set up a radio and antenna in a friends truck. We went from 1:3.5 and not being able to transmit further than across town (small town) to 1.1.5 with it and I can hear him about 7 miles away on the interstate and 20 miles over water.
Using the same meter I was able to get my mobile antenna, a wilson flex 3', down to 1:2 I had to take the tuning rod all the way out. with this we were able to talk that 20 miles over water, it was static filled though after about 15 miles.
I added the amp and my SWR is now almost at 1:4. I bought a 4' wilson flex and a no-name truck stop 4' flex antenna. I can't seem to get either one of them lower than this SWR. I am going to try a Firestik Firefly to try as well. I have replaced my jumper from cheap radio shack coax to mini8, its the best I can find around here. And will be doing the same with the run from the amp to antenna.
It is in a FJ Cruiser using a Bandi Mount. I want the flex antenna as it bounces around off road and seems to hold up the best.
I can not be heard any further than I could before the amp and my signal isn't as strong sounding unless I'm right on top of the other station. My receiving is full of static too.
Do you guys think changing the coax from the amp to the antenna could make a difference to bring my SWR back where it was? If not I think I'm going to dump the amp. I was happy with it before it, just hoping to talk a little further out.
Thanks for any help
Thanks for any help
