I've been recently having a problem that just comes and goes in terms of my 2 meter radio set up.
My set up consists of a Yaesu FT 2800M radio, a Ringo Ranger II antenna and 40 ft of LMR-400 coax. I keep an SWR meter in line with the radio.
I have noticed that sometimes my radios signal will decrease by 3 or 4 bars as opposed to normal and if I key up the SWR is over 5:1. Yet later on the same day without doing anything all of the sudden the signal strength will return to normal and the SWR will be at 1.3:1.
Since my antenna is mounted way up on a pole I haven't had the time to really trouble shoot. I have so far verified that there is continuity at the end of the coax between the center lead and the ground. I know this indicates a short.
However, since it comes and goes (and is not all the time) and also since the radios signal decreases (even on the strongest repeater that is 10 miles away and can be heard for miles) this has me wondering if this is a potential antenna problem...? How common do Ringo Rangers have issues such as mine?
I mean i could be wrong, but I would think if the coax itself were shorted (such as if someone stuck a pin in the coax) that the signal strength would remain the same.....right?
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
