Update: Everything is back installed and up and running. SWR readings when it’s on is staying low, which I know isn’t a true swr reading rather then showing some reflect right? Anyhow, I hammered for about 15 min to some locals about 7 miles and 25 miles away and they said I jump about 2s units and the audio jumps way up and sounds real clean and clear. Voltage drops from 14.8 at a fast idle to about 13.7 on TX. Dash lights dim slightly but not bad at all. Radio and box both stayed very cool to the touch after 15 min. Driving about 1/4 radio power into it, which that is about where the swr reading on the radio is the lowest. So far so good! Now I just need that Ranger SRA 198 and I should be done with this install! Thanks for all the comments and help.
