I’ll start by stating what I have
Swr 2.0 :1 channel 20. 27.205
stryker A10 mag mount 1:1
swr is 2.0 no matter what I try. Changed coax, grounded to several spots, no short. Tested mount, coax and antenna with ohm meter. Is it the location?
The Dark Side can alter your perception of things sometimes but aren’t truck beds bolted directly to the frame without bushings? All of them I’ve did installs on were this way, maybe I need to remove this helmet and look upon it with my own eyes.
Could be! I know my XYL made comment when we drove it home couple years ago, that even with a V8 and Z81 Sport suspension that it was quieter on the interstate at 70+mph than her fancy Ford Escape.
My pic is from an ‘18 Dodge (3/4).
Bed is bolted to welded on mounts.
For companies doing otherwise...I wonder if it’s different from class to class.
My Silverado has rubber bushings and spring bolts. They started that (GM) think 91...as it helps reduce noise...The bed does not float but frame/bolts and bed are all coated/painted also before install.
Maybe mine have all had that noise reduction package, the cab is done that way also...Yes correct, I guess???
