I just got my homemade copper pipe dipole up and hooked up. I checked the SWR on the ground before it went up to get it close and had it at 1.5:1. Checked it after it went up and now I have 2:1 on channels 1, 20, and 40. Some issues I'm concerned with:
1: Do I have it high enough...the radiator is above the roof line at the peak of the roof but the counterpoise is below the roof line....is the an issue?
2: I have 100ft. of Tramflex RG-8X that i have the extra looped (about 4ft. loops) up hanging on the wall. I don't want to cut it because I hope to relocate in the near future......is this an issue?
Pictures of the antenna included.....thanks in advance.
John
P.S. would grounding the antenna help any and where should I terminate the ground wire at the antenna.
John
