King Mudduck said:
I have been to a few sites regarding home built antennas but being new to the radio hobbie i cant really understand how they are built,to much tech stuff i guess.Are there any sites that i could go to are are not quite so hard to understand?
It is very easy to make your OWN "Big Coil" antenna, and the parts are available at your local home and plumbing supply outlet!
10' feet of 1/4" copper tubing
6 1/2" X 1/8" Brass Bushings
1 short section of 3/4' PVC pipe
3/8" opening crimp connectors (2) to fit the 1/4" tubing
3 feet of 3/4" copper tubing (see thread in "discussions" section.)
First decide how LONG you want this antenna to be. Cut this lower mast to suit your requirements--OR you can leave it out and go with base loading. Play with it and see which works best!
Next insert a Brass Bushing into each end of the 3' foot section of 3/4" tubing and secure with JB Weld. Good idea to rivet these in place as well!
Now insert 2 Bushings into the ends of the PVC after cutting the PVC to about 6-8" length. Rivet these in place/JB Weld. This will serve as the center support for your coil antenna.
Now wind about 6-7 turns of the 1/4" copper tubing around a 3-4" form such as a coffee or nut can. Keep the coil turns evenly spaced around this form. Solder the larger crimp connectors one on each end.
You will also need 3 or 4 3/8" X 24 stainless studs and/or collet nuts. These can be found a hamfests and swapmeets. It may also be good to chase the threads in these bushings with a 3/8" X 24 tap.
Insert the studs to hold the coil in place. The lower mast and whip will keep the coil in place. Attach about a 3-4 foot whip and tune. You may have to fiddle with it a bit to get the combination that suits you, but it is an easy build and cheap (about $10 in parts). Experiment and enjoy. The more you make, the better you'll get at it!
CWM
