Decided to try to make my own 11m dipole.
Used an SO239 "Tee", and 2 x 239 fittings. I split 16ga lamp wire down the middle. Each leg is 103.25". I soldered one side to the center signal fitting, and the other to the outer ground fitting.
So then I went to check the SWR before I hung it up. I laid it out, and checked it with TWO different meters. SWR overall is high, almost 10:1.
Any ideas? Do I need a Balun?
-Richard-
-Richard-
