Hopefully can save someone else some time. Embarrassing
Low_Boy
Jan 21, 2010
1,934
1,202
173
Rochester N.Y.
I chased around a problem yesterday that was not a problem at all. I even feel like a fool posting this but hopefully I can save someone else some time if they have this problem.
Working on a radio with no covers yesterday and had the extension speaker plugged in. I kept getting talkback and a squeal. It did not happen with the speaker in the cover but as soon as I hooked up the external I would have this problem. If I moved the speaker plug just right the squeal would go away. I thought the metal ring on the jack was touching the chassis but it was not. After messing with it a while I decided the jack was bad. A, P.I.A. job but I had to do it. I got it all back together and it worked good until I moved the radio. I had the same problem. I replaced all the 102 ceramic disc caps in the microphone socket board even though they were good same problem.
I love this style speaker plug It is very sturdy. Not like the plastic ones you get on e Bay. The plug has a metal body with a plastic sleeve. The speaker jack on this radio is a bit recessed and the metal part of the jack was grounding on the frame of the radio creating the problem. I made a small washer and no more problem.
Looks like a 11/4" jack. I purchased a cobra hg s 500. I enjoyed the sound from the cobra much better than the original Madison speaker I was using along with the uniden madison. I purchased another for my Sonar. Most who use 30-40 year old radio's don't realize the speakers that are original to those rigs have seen better days.
The two cobra external replacements made a big difference for the better.
73's
