i am curious how a coil antenna works.
im talking about monoband VHF & monoband UHF.
including dual band vhf uhf antennas.
today i broke my ANLI dual bander and what was inside? capacitors&copper wire wrapped around plastic insulater, they didnt break but the wire soldered in line with them to the top metal coil antenna which i fixed no problem ( better then they made it )!
the upper whip is 4 turns. while inside below it in a plastic sleeve is several turns of copper wire.
but im curious if lets say you have a 2m 5/8 antenna.... the whip is 52" or more.... now some antennas have the same whip but the center of the middle is like a curly fry OR Internal coil.... what if you took the whip and made all of it coils? or did it every 2" to make the whip less long, and still be strong?
same i fashion for any vhf uhf shf ehf THz.
