Im going to try to put up my A99 in the next few days and going to put a bauln under it. I'm going to use rg213 coax. How many turns do i need to make? Thanks
4 inches is way too small for RG-213. You want to make the coil RADIUS at least 10x the cable's OD. For 213, with an OD of 0.405", that would be a 4 inch RADIUS.
Radius being half the diameter, we're looking at an 8 inch DIAMETER to be on the safe side, especially if you're using significant power or the coax will ever be exposed to hot sunlight day after day.
what should i use to hold my rf choke? Have a pvc t come off the tower to a piece of pvc pipe and just zip tie the choke to that? or actually wrap the coax around it? cuz i havnt seen a piece of 8 inch pvc pipe. Anyone have any pics of their set choke? thanks
