How do you check the input impiedance on the dx500v, to see if its 50ohms. The only way to lower my swr`s, with the amp ON, from over 3, down to 1.3, is to add a 3' jumper on to my 12' of coax, making it 15'.
IT HAS TO BE THE AMP! Ive used 3 diff antennas and got the same reults.
I dont need 15', or even 12', but its the only way to lower the swr with the amp ON! Ive done everything everyone suggested,REDONE ALL THE GROUNDS (plus some), and RESOLDERED ALL Coax ends, and moved the antenna above the cab. The tip is now about 13'high and the antenna is only 5' 5'' tall
